sonsamuray
Hello In the semi-rigid solution of my project, the analysis is interrupted. However, there is no problem in full analysis. I got
Log in or register now.
I took your advice into account. I created a frame system even though beams pass through the rooms. Thank you for your attention. So is there an advantage to making balconies closed cantilevers? Isn't it right in terms of relieving the concrete load on the cantilever beams by forming beams with the floor edge on the console beams?"unver":34jkmebk" said:Hi My Suggestions --If you delete the console tiles at the end of the S21 column from top to bottom, it analyzes, --CORNER COLUMNS DO NOT HAVE A FRAME DURING 5 FLOORS, CREATE A FRAME WITH CORNER COLUMNS ON THE EXTERNAL AXIS OF THE BUILDING. Note: A building with the same corner columns in Eskişehir about 34 years ago. Unver ÖZCANYou do not have permission to view link Log in or register now.
My opinion: There should not be a closed (wall-bearing) beam/slab console protruding outside of the building's outer axes (column-beam frame should be formed)."sonsamuray":1udtmrbk" said:So is there an advantage to making balconies closed cantilevers? Isn't it?
