yes there is, for example all beams( you want to select (on a floor). Select any beam. Click on the beam icon (the icon you use to draw beams) then click on the select all icon (the icon you use to select all elements) so that your beams are selected. You can do the same for all other elements."gürkan":1nkwf4qs" said:SA Hello, in the program, for example, is it possible to select all the beams (or any other object) on the 1st floor (without closing the column panel floors etc. from the layer settings)? ,
need to see the project."gürkan":20le1dzr" said:sa hello In my project, some of the foundation beams (like tk 69 and tk66) have 45Q14 or 30 Q16. It didn't seem normal to me. I would appreciate your help. Shall we change the live load participation coefficient from the hyk part in the floor parameter? thanks
Hello Select any beam in the plan, beam Right-click on it and use the "Select all" command All beams in the plan will be selected."gürkan":e126ne6t" said:SA Hello, is it possible to select all of the beams (or any other object) on 1 floor in the program (without closing the column panel floors etc. from the layer settings)? ,
