"mert62":3apg6mfh" said:
Hello 1) When I right click on the section on the mold plan and want to get a section in my project, I get the error Section - The object to be viewed is not defined. I couldn't find a solution.
Object fragmentation, copying, etc. in the mold plans where the message comes out. transactions have been made. When the mold plan is received again, the "create section" line from the right-click menu can be clicked and the mold plan section can be taken.
2) Dimensions do not come automatically in formwork plans. The red arrows are coming, but the measurement texts are not coming, I have to manually enter them one by one. I would be grateful if you could help.
"Show current distances" in pattern plan settings Uncheck the line and get the pattern plan. Also, run the Calculate contour command for dimensioning the axis distances. For curtain cutting safety issues, you can review the knowledge base link below.
Curtains with an L cross-section (P05) -P03 etc.) should be modeled as a group curtain.
We recommend modeling the elevator shaft as flat and creating the shaft detail drawings using two-dimensional drawing possibilities .
Good work
