Section failure error in columns and beams
mhmt_ali
In the attached project, although I increased the size in some beams, there is no problem on all floors, but there is a problem on the last floor. Is this the only way to scale up? Also, can I get your suggestions on the project I have done? II studies.
Hello My suggestions; --You have entered the floor slabs as cassettes, but these tiles are hollow blocks. In order for it to be a cassette, the gaps must be square or very close to the square, --Mark the tick of the elevator floor, -- Remove the stiffness ticks in the 1st and 2nd basement floors, --It would be better if the curtains were gathered on one side in both directions and distributed evenly, --Your structure Since it is hollow, you should make a MIX solution, --The beams around the building may sag, --Turn back to the column-beam-slab system at this height. --One more suggestion, convert the hollow blocks into square cassettes. Unver ÖZCAN
