Hello, how can I go about removing the "Based Floor second order indicator value is high. Increase system rigidity" warning in the project? Good luck with...
Hi, "Based Floor second order indicator value in the project is high. How can I go about removing the "Increase system rigidity" warning? Take it easy...
Hello, The second order problem is caused by the DG1 console floor slab, which is defined alone in the basement. It is detected as a diaphragm. If you check the "Rigid diaphragm creation" option from the properties of the DG1 tile and analyze, your problem will be solved.
