HELLO FRIENDS, SINCE THE 6 VERSION WAS FIRST COMING, I DID NOT GET ANY APPROACH OR HELP EVEN IF I REPORT THE SAME PROBLEM MANY TIMES. AM I DOING WRONG? WHEN MY EARTHQUAKE CURTAINS IN MY SYSTEM CROSS OR CONNECT AT ONE END WITH BODRUM SURROUNDING CURTAINS ON THE BASEMENT FLOOR, THE SIZE OF THE EARTHQUAKE SCREEN IN THE BASEMENT IS CHANGED. THIS CHANGE CAN BE SEEN IN THE CURTAIN DETAILS. THEREFORE, SOMETIMES, SUCH AS 25x175, MY EARTHQUAKE CURTAINS SHALL BE REDUCED TO 25x150 DIMENSIONS, SUCH A HEAD CANNOT BE CREATED ON THE BASEMENT FLOOR, AND ALSO CHALLENGE WRONG READINGS. WHEN THE ACCOUNTS ARE EXAMINED, WE SEE THAT THE SAME SIZE HAS BEEN TAKEN. TO CORRECT THIS, WE PLAY ON THE BODRUM CURTAIN FAILURE, THEN FIX IT AGAIN ETC.. CAN A SOLUTION BE GIVEN TO THIS ISSUE? GOOD WORK EVERYONE...
