Hello there; Try changing your selection perpendicular to the bar and now parallel. Apart from this, try making changes in the lower and upper heading placement directions in the section section of the scissor settings. If there are still problems, you will need to edit the detail drawings from the drawings. It will not cause problems in terms of analysis and design. In this process, we will examine it, if there is a programmatic error, it will be noted for the solution. Good work.
