Hello, in ideCAD Static, drawings are always created 1/1, scale is given at the output stage. When you export DWG, it is exported as 1/1 in the same way. If you want to print a 1/50 drawing and a 1/20 drawing side by side, you need to scale the 1/20 drawing by 2.5 times. You can print at 1/50 scale. The reason why drawings are always created 1/1 in ideCAD is to make 2d drawing corrections easier. If necessary, I recommend scaling after making 2D drawing corrections.
