scaffolding views
bartayd
The drawing gives a front view of the pier, but not a side view. when we want to take it as a side view, the drawings can be troublesome. It will be very useful both in terms of drawing and time if it automatically draws side views from every front except for the views while taking the scaffolding drawing after the analysis.
Hello there; Side views are included in the drawings. Can you specify which version you are using? If there is an error in the version, work can be done to take the necessary action, or if there is a problem with your modeling or settings, we can help you with the solution. I will ask you to send your project. Good work.
By appearance, I mean not facade views, but consider that we take sections from the pier. At least one length section can be added. A section or view drawn with non-detail elevations.
