Scaffolding project offset settings
201968
Good afternoon How can I adjust the offset settings in the Scaffolding project. For example, the exits on the 1st floor are not on the ground floor. How can I capture the upper floor corners to draw the scaffolding project from the ground floor?
Re: SCAFFOLD PROJECT SCAFFOLD ALIGNMENT SETTINGS
"201968":14onaf8d" said:
Good day, how can I adjust the misalignment settings in the Scaffolding project.
Hello, -You can change the direction by pressing the space bar while drawing the scaffold. then you can change the direction by checking/unchecking the "Direction" cell in the pier settings
For example, exits on the 1st floor are not on the ground floor. How can I capture the upper floor corners to draw the scaffolding project from the ground floor?
You can draw a reference object - axis - to the relevant coordinate. -You can learn about scaffolding modeling from the links below.
