scaffolding project HK.
bha
Good day, I am trying to draw an ide scaffolding project, I did some research on the forum, it was said to examine the scaffolding project in the demo, but I could not find the mentioned project, I am adding it myself, where is the error in the model, thanks
I want to ask you something my friend, I will be glad if you answer I am using reinforced concrete, I have updated the scaffolding macro. I did a scaffolding work, but I can't do what you describe. For example, when I click on the steel beam tab, there are no freedoms and design tabs like you do. I can work on the block. I tried to shred the object but it doesn't. It says that the scaffold object cannot be disintegrated in the reinforced concrete project. ( my reason for doing this process is to try and select the beams one by one). What is the reason for this? can you help me? Thank you.
"erbilsancaktar":2x028e0b" said:
My friend I want to ask something, I will be glad if you answer. I am using reinforced concrete, I have updated the scaffolding macro. I did scaffolding work, but I cannot do what you describe. For example, when I click on the steel beam tab, the freedoms and design tabs appear No. I can work on the block. I tried to break the object apart, but it does not. It says that the scaffold object cannot be split in the reinforced concrete project. (The reason for doing this is to try and select the beams one by one. What is the reason for this? Can you help me? Thank you.
Scaffolding Scaffolding elements that are modeled with the Scaffolding macro are automatically assigned freedoms. You don't need to do the things described here manually. What is explained here is about creating a manual scaffolding using ideCAD Steel 8.0 and steel columns, steel beams and braces without using the scaffolding macro. What is explained here is done automatically with the scaffolding macro. It is not possible to split the scaffold created with the scaffold macro in ideCAD Reinforced Concrete 8.5. This facility is available in the ideCAD Steel 8.5 program. With ideCAD Steel 8.5, it is possible to work with the Scaffold macro, or it can be modeled from scratch if desired.
