Scaffolding project combinations
After creating the scaffolding project, there are many options on how to create joints, but which one is the appropriate one or is it possible without assigning a joint?
Re: PIER PROJECT COMBINATIONS Hello; You don't need to define a join. As long as you follow the rules (freedoms) in the
link, you need to create joins. not required. Good work.
If you give freedom to the ends of the cantilever beams connected to the building in the scaffolding in the direction of the building, the analysis will not be performed. If there is another problem, unfortunately there is no way for me to help you without seeing your project. Good work.
Hello there; Open a new project. In the new project, model and analyze a single solid first. In the meantime, make your column height the same as your floor heights in the floor general settings. After analyzing a single layer, copy layers. However, in floor copying, steel columns are not copied, so in each floor's own plan, enter the columns so that they are the same height as the height of that floor. Pay attention to the freedom of your beams. There are beams that you have overlooked and that have looseness in the wrong place. Examine the scaffolding model in the demo carefully. Good work.
