Re: scaffolding fails on all elements. Hello; There are unit errors in fixed and live loads on your scaffolding slabs, and quite high values appear. The required fixed load is 0.075 tf/m^2 , and the live load is 0.1 tf/m^2 . If you edit in this way, your design values are improved. Also, the program takes the total height of the scaffolding from the floor general settings. In your project, you can change the number of scaffolding floors to 6, as the building continues only on the middle axis of the building on the last floor. Good work.
