Scaffolding Drawings
acgyapi
Hello... In the scaffolding project I have attached, there are unidentified objects on the ground floor. It also appears in the scaffolding drawings. I make an object and delete it. That's how I draw. He's been doing this for the last few projects. I don't know if it's related to this but I can't get the scaffold perspective drawing either.
Hello, the objects that appear as blocks in 3 dimensions come from the dwg drawing you imported. If you delete the imported drawings before starting the scaffolding drawings, you probably will not encounter this situation. If you add the project file that has not been registered as a scaffolding project and the dwg file you imported, we can examine it in detail. Good work.
As you said, there is a layer called geometric object implicitly. I opened it and deleted the 2D objects. The drawings have improved. But I still can't get isometric view in scaffolding drawings. I was able to get it before. As an example, the scaffolding project I copied has an isometric view. But in the project I prepared as an experiment, isometric view is not drawn in the scaffolding drawings. I would be glad if you help.
Hello again, As in the example you added in the Scaffolding project, if there is a scaffolding only in the Y direction and to the left of the structure, then isometric images are not drawn. I'm putting this in our notes. If scaffolding is drawn in other aspects of the building, isometric drawings will be created.
