hakanyalciner
Hello, I wanted to apply push analysis for a simple framework imported from IdeCAD to SAP 2000. But I came across a warning in the assignment of plastic joints. In the form that the appropriate material or section is not available. Even though the material and section properties defined in ideCAD and included in the SAP were assigned to the relevant reinforced concrete elements, the same problem persisted. As a solution, redefining materials and sections and reassigning them solved the solution. However, in this case, the loads previously assigned from IDECAD have changed. In addition, when imported from ideCAD, entering the section properties in SAP, the reinforcement properties tab is not allowed to be opened. Thank you for the help of friends who have experience on the subject, Hakan YALÇINER
