S04 S06 Stapling error in columns
Re: PUNCHING ERROR Hello, You have drawn a continuous foundation in the wrong contour of your basic design and defined a raft foundation in it. You cannot model such a base in 7 versions. There will be no load transfer with the raft foundation. It can be solved as of version 8.504. If you want to model a rafter raft foundation, connect all columns and walls with continuous foundations as a grid and define a raft foundation inside. Columns and curtains should not come to the raft parts. or you can make a beamless plate raft foundation. In this case, draw the perimeter of the foundation with the slab edge in foundation mode and define a raft foundation in it. Do not model the elevator pit in a raft foundation. Erase the small foundation. Make the curtain jeans 0. Check out the link below about elevator shaft detail and modeling.
The document describing the solution methods of column-beam junction safety errors is attached.
Re: Stapling line Thank you, Mr. Yasin, the problem with the column and beam has been solved, but this time the floor safety increased the negative thickness and made the reinforcement double-sided long, but it doesn't work, what should I do?
Re: Stapling line
Hello, the final version of the project is attached. As a result, FLOOR SAFETY IS NEGATIVE and there is no possibility of improvement of the ground, unfortunately, how can I solve this problem, what are the deficiencies in the structure, I am waiting for the help of experienced colleagues. good work.
Re: Stapling line Hello, I corrected your project, a few beams and columns (ab) error remained. Note: I suggest you post your problem in one place in the forum. Ünver ÖZCAN
Re: Stapling error Hello Unver, first of all, it will be a late thank you, but I thank you very much. Since I had to deliver the project within that day, I did not look at the messages after a certain hour when I did not receive a reply. And I made a raft with beams by passing each column between each column with beams. I solved it with 60 and carried it when I entered the system again. But I would like to know how you solved the radial system, what were my mistakes and deficiencies, what should I do in such large and gradual projects, can you briefly answer me? Thank you very much for your interest. Good work.
