Rptexe error
erbilsancaktar
After analyzing my project, I can create a report, but when I say save as and want to save it as pdf, after waiting 10-15 seconds, rptexe has stopped working. Saved the metering report as pdf, but did not save the calculation report. While drawing my project, column beam foundation etc. I changed the writing style from arial to another style. could it be for him? And what is the solution? I tried it again, but it gave the same error. It does not give this error in any other project. I'm sure it was because I was playing around with font styles. Can you help with the solution?
Hello, We had the same problem, I forwarded your project to arge for solution. If you have one of the PDF printer programs, after you get a report in this project, "Print.." From here, select the PDF printer as the printer type and print it, you can convert it to PDF in this way. You can find the report of your project in the attached form.
