Rotation around the Z axis
If you want to rotate the elements around the Z axis, you can use the command "Rotate". If you are talking about a different situation, can you give detailed information about the operation you want to do by adding a project file or a screenshot?
"Levent Özpak":16l5usoj" said:
If you want the elements around the Z axis, you can use the "Rotate" command. If you are talking about a different situation, the project file or screenshot of the operation you want to do Can you give detailed information by adding it?
rotates in x and y axis with rotate command like this, does not rotate in other axis
The standard rotate command rotates around the Z axis (in the plan plane) :) What exactly are you trying to do to which element in a project?
