Hello. I think there are 2 problems when I use the Modify->Rotate Structure command in Idestatic version 7.017. The first is that Rx and Ry are not automatically changed. The second is that the polygon columns in the structure exceed the Maximum Pursantage when all of the polygon columns are analyzed after rotating the structure. I guess the program does not change the Ix and Iy of the columns. This problem was solved when I drew again and created a polygon column. I haven't tried version 7.018 yet, is this problem solved?
