Roof with truss system on reinforced concrete
masmay
I WANT TO FIT A SCISSORS SYSTEM ROOF ON A BUILDING WITH REINFORCED CONCRETE COLUMNS+FLOORING. IT IS A SITUATION THAT CANNOT BE A DEPLOYMENT PROBLEM. I CANNOT ANALYZE REINFORCED CONCRETE AND THIS ROOF SYSTEM AT THE SAME TIME. THE SYSTEM SAYS IT CAN'T SOLVE AND SHUT UP.. - I FURTHER I WANT TO ANCHORAGE THESE SCISSORS TO THE ROOF ON THE COLUMN HOW CAN I SHOW THIS. IS IT POSSIBLE FOR ONE SIDE TO HAVE A SLIDING JOINT IN THIS ANCHOR?
Hello there ; If you are getting the system cannot be resolved error, there is a modeling error in your project. However, it is very difficult for us to make any comments without examining your project, can you send your project? - Support joint has different sub-types as fixed and sliding. It is suitable for use in your structure. Good work.
Good afternoon, I am having difficulty in applying the appropriate combination because the subtitle is linear in the roof truss I have added in the picture, can you help me?
Hello there; Correct the posture of the diagonals so that the joint can be formed properly. Use the pre-selection in the direction selection in the cross menu. The joint will fit into the scissors upper head. Good work.
Thank you for the information you gave about the crosses, Ms. Nurgül, I am aware that she was wrong, I made the correction. but what I really want to ask is is there a combination you can suggest for the combination of reinforced concrete column and truss?
