Roof Lovers
serdagi
Hello, I solved some of my problems with roof lovers in the message
. I'm still having trouble with the roof lovers. I am sending pictures of the project and its errors in the attachment. While I can choose the purlin connection profiles on the left side of the steel project as I want, on the right side, it does not work even though I do it with import-transfer from the object.
Hello there; Whatever the problem you have with lovers, such a situation does not occur on your project that you sent before. You may have taken an incorrect step during modeling in your project. That's why we need the current version of your project, on behalf of it to identify and solve the problem. If the joint of beam joint with butt plate is symmetrical with the shape specified in the literature and modeled with 4 bolts, you can obtain the design report as you can see in the image. Otherwise, the design report of the combination gives a warning. Good work.
Hello there; You have defined twice on your first and last span main beams, so you have overlapping elements in the same coordinates, but when modeling the purlin you have chosen different ones than the overlapping beams when modeling the different joint. Therefore, there was a problem in your love unions. At the same time, the right end elevations of your main beams were 5 cm different from each other in both directions and the purlins were not touching the beams. These errors have been corrected. It is useful to pay attention to the elements you choose during modelling. Good work.
Dear Nurgulkaya; Thank you for the correction, one more thing, I fixed the union controls according to the warnings, but I could not see the wrong union in the conflict controls, but it shows a lot of errors, and I could not find the union and conflict control in the ribbon menu. I was able to switch these controls to the classic and do it there. good work
Hello there; Conflict check is available in the steel subtab in the analysis and design tab in the ribbon menu. When any of the errors listed in the conflict check is selected, both elements light up red and the program moves closer to that area. Good work.
