eissenhover
Hello everyone, I had a few questions, I would be very happy if you could answer them. 1) When I make an "angle joint" between the column and beam, for example, there is a moment-free connection as you can see in the picture. when I make a welded joint of the same elements, when I look at the element end freedoms in the analysis model, there is no moment-rotation. Is a welded joint a rigid joint that does not transmit torque? 2) My other question is what are the tricks of understanding whether a joint transfers moment by looking at its type, for example, how do we know whether the angle joint in the picture transfers moment without looking at the end freedoms, that is, without looking at any analysis results, I would like to ask you in rough terms, the angular joint you see in the picture does not transfer moment and does not allow rotation. is given, but if I see this production in the field, I would ask myself how it can rotate, so this rotation event does not sit in my mind.
