Hello Typical beam may not be defined in the floor. Select the tile and click the "Specify Typical Beam" command using the right-click menu. and select a rib beam in the Slab by left-clicking the mouse, the typical beam color will be different from other beams. When specifying typical joists, make sure they are continuous with the typical joists of adjacent floors. Good work.
