If you define a direction from a beam other than the beams around the floor in rib slabs, the typical tooth does not continue and gives the expansions in pieces. As a solution to this, after adjusting the slab misalignment to meet each other, you will need to specify the typical beam from the command (you can find it in the commands in the slab toolbar) again, provided that you select the typical beam 2 times.
