Reverse beam and beam height
mehmet2015
I get the warning that the height of the beam that I run as a reverse beam cannot be less than 3 times the floor thickness, but there should be no problem at 3 times my floor thickness. And I would appreciate it if you would review the project in general good work
Hello, D01(15 cm), D14(14 cm) and D19(16 cm) console floors are considered to be connected to K22, K23 and K24(25*36) beams. That's why you're getting this warning. Note: The 1st basement floor is considered rigid in the floor general settings. It would be appropriate not to be considered rigid. Good work.
