izmirlimuhendis
I have a few questions about the retrofit project I sent in the example. I will be glad if it is answered.. I created the system. After adding the sheathings and making a "linear performance analysis" and getting a reinforcement report, I see that the targeted performance level in the building performance evaluation part of the report, the "Immediate Use" performance level, is not achieved. What I want to ask is: Do all of the beams have to stay in the minimum zone? If it is necessary to strengthen the beams, why not beam reinforcement in the idea. ? What should I do to strengthen the beams? I want to put a reinforcement screen under some beams. Should I draw the reinforcement curtain by lowering the upper level of the curtain as much as the beam level? When I look at the Earthquake Code, I am asked to solve the building for which I have solved the project with the target of "Immediate Use" against a design earthquake with a probability of exceeding 10% in 50 years, "Life Safety" against a design earthquake with a probability of exceedance of 2% in 50 years, with the performance target? Which one should I choose in the project. Should I make a solution for both of them separately? I would also be happy if the project team members make a general assessment about the project.
