When I draw an L-shaped retaining wall, the report shows the solution and anchors of the trapezoidal and basically threaded retaining wall. The picture is a representation. If your retaining wall is L type, it will be seen that the Lo or La value is zero in the building size information, and the wall top and bottom widths are the same. The base tooth information will not be printed because there is no base tooth. Also, in the 3D image you added, it will be seen that the ampatment is both in front of and behind the wall. good work
