retaining wall
Yes... Indicates insufficient reinforcements. The problem can be solved by selecting larger reinforcement diameters from the Retaining Wall Reinforcement selection dialog and performing a retaining wall analysis.
"yılmaz polat":2z5rfo3q" said:
http://dosya.co/9wchcf54cef5/700_cm_istinat_duvarı.ide7.html can you download and check the file from here. Also, what do you think should be the maximum height and length of retaining walls. (a certain limit in idecad) Is there any )
In the reinforcement selection dialog, the problem is solved if you select 20 reinforcement diameter for the Console vertical reinforcement and perform a retaining wall analysis. There is no limit to the height of the wall in the program. However, in the sources it is said that the Console type retaining walls are usually made at a height of 3-8 meters. For more information, you can review the topic of Retaining Walls from the Book of Reinforced Concrete Structures by Zekai Celep-Nahit Kumbasar.
