Retaining Wall TBDY2018 Compatibility
eissenhover
Hello, I'm a user of idecad v10, the rollover coefficient in TBDY2018 appears as 1.3, in ide v10 it appears as 1.2, is there any 2018 compatibility related to retaining walls, or am I confusing the concepts?
"Ismail Hakki Feeds":179k5skt" said:
"MaFiAMaX":179k5skt" said:
Hi, When will the retaining wall be updated according to the new regulation?
There is no set date for when it will be updated yet. However, it will not be included in the upcoming update. The next update will include risky builds, while the next update will include linear performance analysis.
Thank you Mr. Hakan, I also manually change the coefficient to 1.3 for earthquake and non-earthquake situations. If the calculation is made in this way, do we meet all the requirements for the 2018 regulation, is all the other infrastructure in the program compatible with 2018?
"eissenhover":1bts2mtw" said:
thanks Mr. Hakan, I also manually change the coefficient to 1.3 for earthquake and non-earthquake situations, if the calculation is made in this way, do we meet all the requirements for the 2018 regulation, is all the other infrastructure in the program compatible? By 2018?
Hi, No, there are static and dynamic earth pressure calculations connected to Sds in the following 16.12. It used to be connected to Ao.
