Even when the ground level is 1 m, it does not save from tipping anyway. There were strange figures in the report when the ground level was 1m. It doesn't save even when the ground level is 1.5 m, but figures like 1 # have improved in the report. You control it manually. See the report. It is very clear how the calculation is done. Tell ideYapı that it should save here, but it does not. If it saves when you calculate it, of course. There is no place for such roundabouts in engineering. It either saves or it does not. It has to save , not just engineering terminology. Good luck with
