Hello, when idecadte is doing a retaining solution, when the cohesion value from the ground survey is entered, the slip verifications on the retaining are not possible, it does not save. soil survey values soil group/class C/Z2 qem=1.7 kg/cm2 internal friction angle 35-45 degrees cohesion 7.7 kg/cm2 bearing coefficient 2040 t/m3 is there a problem with the units?... idecadte cohesion default its value is 0.9 t/m2
