s.varlik.celik
Hello, I have a problem, I would appreciate if you can help. I have a system like the one in the appendix and I decided to make a raft with beams for the foundation since the ground bearing capacity is low. However, when I look at the crust results after the analysis, all of the soil stresses are 0 tf/m2. When I click on the Force and reinforcement fields tab, I see meaningless values as below.
Log in or register now.
Could I be making a mistake somewhere? Let me tell you a mistake I may have made on the subject. When I first designed the foundation, I did the analysis and some of my beams and two raft slabs had Zq negatives (although my beams were problematic, I got a non-zero value). I did some resizing on some beams to fix the issues. Before performing the analysis again, I canceled the automatic analysis creation by clicking the "Create automatic analysis system" button and clicked the "Create analysis system" button next to it. When I did the analysis later, I encountered such a situation. Moreover, the moments have been reset in my beams on all floors... A few information about the system All foundation beams are 100cm deep. Widths can vary. The rafts are 50 cm thick and at -50 elevation. I made a superstructure interactive solution. What do you think could be the problem? Addendum:
