Relative story drift problem
ismihankaya
friends, in my attached project, I am getting a relative floor drift error. The project is a pre-sedimentation pool project at a depth of 3.10 meters from the ground. I can't get rid of this error no matter what I did.
You entered the floor height and R (bearing system behavior coefficient) incorrectly. Enter the floor height 300 cm from the floor settings, set R=7, the problem is solved.
"ismihankaya":3d9yrbsu" said:
friends, I am getting a relative floor drift error in my attached project. The project is a pre-sedimentation pool project at a depth of 3.10 meters from the ground. I can't get rid of this error no matter what I did. You entered the floor height as zero. The floor must be defined for the regulation controls. Enter the floor height instead of the elevation arrangement on the panels.
