sema kalaycı
I can't fix the relative floor offsets, can you help?
"Emre.Ozcan":rspredn9" said:If you click the 2nd option to connect the infill walls made of brittle material or frame elements to the structure from the Tbdy options section in the Analysis Settings section, the facade elements will be connected with flexible connections or the infill walls will be independent option. ] What you say is true, but it must be done as the regulation describes in its application. For your information, these applications are not very common in standard residential buildings.
"Emre.Ozcan":hof5ieyj" said:Tbdy in Analysis Settings If you click on the option 2, the connection of infill walls made of brittle material or frame elements to the structure from the options section, the facade elements are connected with flexible connections or the infill walls are independent option. Unver ÖZCAN
