Relative floor offset
Hello there; You can use the projects sent to you as suggestions. It will be beneficial to use the columns and curtains in both directions with appropriate and close to each other rigidity if you make a general system improvement. In cases where you cannot change the geometry, you need to increase the column sections. Good work.
Hello
"mertknk":1j7dd6ra" said:
I couldn't fix the relative floor offset error, how can I solve it provided that the regulation 4.9.1.3 is adhered to.
My suggestions: --Fix the errors in the geometry control, (tile edge line adjacent to the beam) var delete and remove.) --Each side is fixed in the stair bracing, fix the bracing, --Make a solution by making all the finite elements 0.25 m in the last calculation. When the above arrangements are made, the relative floor drift error does not get fixed. Add curtains. Ünver ÖZCAN
