Relative floor offset
hello, your project is having trouble in the y direction, the displacements are high in the area I marked. The direction of the curtain and column should be changed in that area. You have defined the floor in the area with the stairs, your definition of the ladder would be more appropriate, your beam passes where there is a chimney. Take care...
Hi My Suggestions: --Put the S82 column on the left outer axle, --Make the P350 curtains you named with the same name as columns, --Make the beams K1571-K1521 25/50, (let the frame be formed, reduce the displacement.) --Make the outer beams 25/50 , --Increase the raft additional reinforcement, --You can remove the bulky curtains P369-P6 on the right. Unver ÖZCAN
