Relative Floor Offset Problem
spirituality
Relative floor offsets in the Y direction do not save, whatever I did, it did not improve. The architecture is not very flexible in the project.
If you make the right and left arms of the elevator curtains, you will make the structure more rigid in the Y direction. Thus, you solve the relative story drift problem. In this way, you have the opportunity to reduce some column sizes. In such a structure, square columns instead of 80/40 columns reduce the dimensions and increase the bearing capacity. S1 column dimensions are incorrect in the ground and basement. The S60 column is not connected in the x direction. The necessity of S58, 59 columns is discussed. The direction of all the columns on the E (or O) axis is in the x direction. As such, you had to bring the dimensions up to 80/40. Examine the roof beam and floor loads. Include stair loads in my site. ..........
