Relative floor offset problem and ground safety negative error
gigiveryon
Hello, 1) Despite adding curtains in my project, there were always different problems on the weak sides. The curtainless and curtained versions of the projects are attached. I cannot change the columns in the selected area in the y direction due to the architecture
Your comments and help in advance Thanks for.
example1_curtain.ide10.html
example2_perdeli.ide10.html
Re: Relative floor drift problem and ground safety negative error I made a mistake while adding it in the curtainless project.
The ground values are like this.
Re: Relative floor displacement problem and ground safety negative error Hello Suggestions: (For curtained building) -- Mark the stair tower floor as rigid, -- Brace the ladder, -- K58 beam on the mezzanine floor to fit the stair landing give, --You have cantilever beams removed from S11-S13 columns (not suitable), create a frame by adding beams to the continuation, --Your soil bearing capacity values are too low, you should do ground improvement, (Why would the municipality build such a ground?) Unver ÖZCAN
"unver":139i4mn4" said:
Hello Suggestions: (For building with curtain wall) --Mark the stair tower floor as rigid, --Support the stair, --Give the K58 beam on the mezzanine so that the stair landing will fit, --You have removed the cantilever beam from the S11-S13 columns (not suitable), create a frame by adding beams to the continuation, --Your ground bearing capacity values are too low, you should do ground improvement, (Why should the municipality build such a floor? Unver ÖZCAN
First of all, thank you very much for your answer, Do we do the job of recognizing the stair tower as rigid by selecting the elevator and engine room in the floor general settings because when I define it as rigid in the x and y directions, it automatically selects the lower floors? I'm getting a payload error up to what value can we ignore it?
Re: Relative floor drift problem and ground safety negative error Hello
"gigiveryon":bki7i4v5" said:
Are we doing the job of recognizing the stair tower rigidly by selecting elevator and engine room in the floor general settings because in x and y directions? When I define it as rigid, it automatically selects the lower floors ?
Mark it as Elevator/Machine room,
Also, in some projects, I get a negative bearing capacity error, up to what value can we ignore it?
İsmail There are brain explanations, check out the links below.
Ünver ÖZCAN
"unver":1fid2s4t" said:
Hello
"gigiveryon":1fid2s4t" said:
The job of recognizing the stair tower as rigid is in the floor general settings of the elevator and Are we doing it by choosing the engine room because when I define it as rigid in the x and y directions, it automatically selects the lower floors as well?
Mark it as Elevator/Engine room,
Also in some projects, I get a negative bearing capacity error, which can we ignore it up to the value?
There are explanations of İsmail brain, check the links below
Ünver ÖZCAN
Thank you very much for your information and answers :)
Re: Relative floor displacement problem and ground safety negative error hello unver sir 1.mark the stair tower floor as rigid in the explanations above 2.mark it as elevator/machinery room 1.in which cases can it be done :?: 2.second In order not to add bys to the situation (it does not affect the system much since it is small compared to the rigidity of the plan).
