Relative floor offset error
mstfdnmz
hello, I could not fix the floor drift and tipping problem related to my project in the appendix. I am waiting for your suggestions for the main factor in the constraints in the architectural project.
perspective window.....analysis model .....you can see x and y components optional reports.....relative floor offset.....Check red lit ticks related to lambda values in x and y direction column or curtains related You can zoom in
Hello, "Facade elements are connected with flexible connections or infill walls are independent" option in the analysis settings can be evaluated, see the attached link for details.
In a building with brick facade infill element, what is the right method for the flexible joint-connected facade element, OR A TABLE WITH A LOT OF COSTS TO REQUEST IT TO BE IMPLEMENTED.
I wrote the option can be evaluated and if you examine the link I gave, the following information is given. "Alternatively, according to 4.9.1.3b, you can consider to form the wall connections independent of the building. Accordingly, you can increase the relative floor drift control limits by 2 times. " Of course, your choice will not be correct if such an application is not made on site. It depends on your preference whether to evaluate the cost issue and apply it.
