related to floor deflection control
profesyonel
hello added rrojede ground floor console floor kd204 exceeds the deflection limit. As can be seen in the ss in the link, the account axis no. 1 is faulty. Even though I copied the solid from the top and created the model from scratch a few times, I came across the same error, if you could help me, I would be very grateful.
Hello, The meshes are formed incorrectly in the slab analysis on the ground floor. The problem was caused by the D201 tile. Connect the upper slab edge of the KD201 balcony slab to the P202 panel at the joint. Delete and recreate the D201 tile. Perform slab analysis. Good work
Thank you very much Mr. Levent for your attention, when I did as you said, the problem was solved. Thanks again for your interest.
