Reinforcements of beams, one continuous and the other discontinuous
mkirann
Hello there. One of the reinforcements of the marked beams in the images I will send in the attachment is continuous and the other is discontinuous. Both are at the same angle, 10 degrees. I entered the angle difference in the parameters. Why doesn't the equipment of the other continue all the time? I would be glad if you help.
Re: BEAM CONTINUITY
"mkirann":1dtvtc5v" said:
Hi. One of the reinforcements of the marked beams in the attached images is continuous and one is discontinuous. Both are at the same angle of 10 degrees. I entered the angle difference in the parameters. Why is it in the other one? I would appreciate your help.
Hello, because the view direction of the beam named K147 is different from the other beams, it is not constantly drawn. Make the view direction of the K147 beam compatible with the other beams with the command "Change/Beam-Foundation/Identify Object Direction" . Good work
