Reinforcements come as sub-reinforcement in hollow block results
ssesli
Hi, I'm defining Ribbed or Cassette flooring. but in the laying results, the reinforcements come as sub-reinforcements. Especially, even though I select the top with the edit command of the account axis, it still throws the bottom reinforcement. Where could the problem be?
Re: Hollow Flooring Hello, bending reinforcement is not calculated in hollow floor slabs, fi8/18 distribution reinforcement is placed on the slabs. If the user wants, he can edit from the Slab Reinforced Concrete dialog. good work
Re: Filler Flooring Hi Levent, I meant that in the previous versions, the dispersion equipment was thrown as the top. It now discards all scatter rebars as sub rebars, and it appears next to the length of each rebar. That's the real problem. Thank you
Re: Hollow Flooring
"ssesli":1tddd7cr" said:
Hi, Mr. Levent, What I meant was that in previous versions, the dispersion equipment was thrown as the top. Now it assigns all the distribution equipment as the bottom reinforcement, and this means that the length of each reinforcement This is the main problem. Thank you
Hello again, slab distribution reinforcement is placed as sub-flat reinforcement in hollow floor slabs. It was used this way in previous versions as well. Only the word "bottom" was not written next to the reinforcement in the formwork plan. TS 500 article 11.3 on the subject You can refer to .1 and figure 11.1. Good work
On a 7 cm plate, there will be 1.5 cm rust margins from the bottom and the top, and the reinforcement thickness of 1.6 cm in total makes a total of 4.6 cm anyway.
