reinforcement thickness
Sir, what I am talking about is not the reinforcement text, but how we can make the reinforcement itself thicker compared to other lines. When you do what you say, the reinforcement text changes.
You cannot do this automatically while creating the drawings. If you want, after creating the drawings, turn off the other layers except the Reinforcement line layer, only the reinforcements will be visible. explode drawings and enter line properties. Line thickness can be changed from this dialog. Line thickness is visual only. Color-related pen thicknesses are taken into account in the printouts.
"yilmaz polat":36loq70e" said:
this is how I am asking about the line thickness of the reinforcement.
Hello, The purpose of your question is not clear, so I will try to answer it by guessing: 1) If your aim is to examine on the screen, in addition to what Yasin has written; If you want to see the layout, select that sheet. Switch to the drawing section from the Project/Draw menu. Adjust the pen thicknesses and paper size according to the colors you use. Press the Predict button, each line will appear at the thickness you set. 2) If your aim is to transfer pen thicknesses to the autoket, check the link below: [url ]http://www.idecadsupport.com/forum/viewtopic.php?f=21&t=1630[/url] 3) If your aim is to adjust the pen thickness while printing on paper, click Settings/Color Pen Thickness, then press F1 and press about the subject. get help.
