Reinforcement Revision
furkanelbir24
After completing the project in IdeCAD, is it possible to manually change the lengths of the reinforcement (the miter lengths, the lengths of the stand legs, the overlap lengths, etc.)?
"furkanelbir24":1t9oclt5" said:
redirected to a different page than the one I mentioned. To a page about 2D
The topic you mentioned is about 2D drawing possibilities. At least that's how I understood it.
"furkanelbir24":1zeunjd3" said:
After completing the project in İdeCAD, is it possible to manually change the reinforcement lengths (miter lengths, the lengths of the stand legs, the overlap lengths, etc.)?
Hello, From the general reinforced concrete parameters, the reinforcement length and You can interfere with the sprout lengths on the curtains. Overlap on columns is automatically made by the program up to lb according to TBDY 2018. You can manually edit the overlap length on columns using two-dimensional possibilities. You can also interfere with the dimensions of the table reinforcement and the minimum miter length from the raft basic settings. Good work.
