First of all, I wish you a good work ... I have one type lodging project, the project of which was made in 83. I entered the program in accordance with the dimensions and dimensions of the column beams and the reinforcements in the project, and locked them from the lock tab. However, I had a little trouble with crossties and stirrups. There are double stirrups in some columns, for example, there are double stirrups in the form of square and rhombus in square columns, how can I enter this in the program as 2 jumps each, or is there not such an option NOTE: Smash the objects one layer from the column application plan I can do it this way by drawing crossties or stirrups from the draw tab, but is there a way to do this from the reinforced concrete tab.... Thank you in advance for your cvps and I wish you a good work.
