"abaci09":345ov2fs" said:I wonder why there is too much reinforcement in some of the ground floor columns. I would appreciate it if you could examine and tell me.
In which law of my building inspection it says that the short column edge should be 30 cm? If so, why do we comply with TDY 2007? 40 cm If there is no problem in terms of static calculation and TDY 2007 is suitable, I think there is no problem."GETA":od04hp5c" said:After the building inspection law, the short side of the column must be at least 30.
there was a break in the building inspection control sheet "Is the column short side less than 30cm?" I don't know if there is such a phrase, but now I think that 25 cm cross-section is not an insufficient cross-section if there is no problem in the static calculation, but in practice, it is a fact that the mold makers can easily slide the columns 2-3 cm according to the sprouts in the application called axis hammer, so I am generally 30 cm at sites that are not under my control. I don't use less slices than"unver":2f67bigd" said:Sn GETAIn which law of my building inspection it says that the short column edge should be 30 cm ? If so, why do we sleep in TDY 2007? If he says 40 cm, will we follow him? If there is no problem as a static calculation and TDY 2007 is appropriate, I think there is no problem. Greetings. Ünver ÖZCAN"GETA":2f67bigd" said:After the building inspection law, the short side of the column should be at least 30.
