thank you very much for the information you have given. But I have problems with using the program for cork flooring, more precisely, I do not understand whether I have made the right calculation model, I would like to express a few questions, I would be very happy if you could help me. 1- On the floor with cork flooring, when I turn around the elevator and stairs or the outer contours with beams, the working and support types of the floors seem to dissolve the beamed slab, as it should not be in the cork. For example, when a single slab is in the form of a mushroom, there is no beam on the floor, but the support type appears as a headless floor type without beam. However, when there are beams on the floor, there are expressions such as simple support type that works in both directions, should they be absent in mushroom design? 3-If there are beams on the floor, it does not do the punching calculations on the floor without defining a 0-dimensional header for the columns, so the presence of beams on the floor invalidates the model in the form of cork flooring in the form of a plaque
