First of all, it's easy for everyone. I just started doing reinforced concrete projects. So there is a lot of lack of experience. When I compare the reinforcements calculated by the program for continuous foundations in a 1 basement + 3 storey housing project I have done with the same type of projects, it is almost 1/3 less. To give an example, in a project of the same type, a foundation beam with a span of 4 m has 16fi 16, while I have 5fi16 reinforcement at 4.5 m. When I examine the moments and axial loads in the calculation reports, they are few. I've looked through the project many times but couldn't find any errors. When I talked to the municipality about this issue, they said that many ide users stopped using the program in the new version due to this problem in the foundations. I don't know if there is such a problem, but I think that the idea is more useful and understandable compared to other programs, and I would appreciate it if you could let me know where I went wrong or other deficiencies in the project. Thank you in advance.
