The column is drawn as a painted circle in the longitudinal reinforcement in the application plan. After smashing the objects, the outer circle line can be seen when the "paint inside" line is left in the circle properties. Also, 2 dimensional operations (moving, copying) can be seen in this circle after the object fragmentation process. etc.) Can you explain the situations in which you have difficulty in intervention by giving an example?"muhsin34":5f59q3q6" said:IN COLUMN APPLICATIONS, THERE IS NO ANY LINE AROUND THE CIRCLES THAT EXPRESS LONGITUDINAL REINFORCEMENT, SO THERE CANNOT BE A MULTI-HANDED CASE WHEN THERE IS ONLY A CIRCLE SCREENING. MI ?
