A abaci09 New Member Nov 14, 2014 #1 You do not have permission to view link Log in or register now. 3 of the ground floor columns it looks like the reinforcement is dense in one of them. Can you check it out.... thank you
K kth10 New Member Nov 14, 2014 #2 beam dimensions and loads, floor loads, studs (beams should be connected from column to column as much as possible in a hollow block system)...if you review these, you will have largely eliminated the reinforcement density on the ground floor.
